Protection for woodwork from stove heat
Rafiki
20 Jul 2009
North Bucks
In the process of replacing my stove. The new one fits lower than the old one (moving it upwards would be a hell of a job I don't want to take on ). Perfectly usable in this lower position, gimballs correctly etc. The only problem is that the rather nice teak edges of the work surface will likely get badly scorched. I was thinking of 'protecting' them in some way with a screw on cover of some sorts - but what? Metal will conduct heat, so you dont solve the problem, plastic will melt. Is there anything else other than sacrificial strips of wood, which I dont really want as will be even nearer to the flame.
Any ideas?
Andrew
pvb
UK East Coast
I'd use pieces of thin angle section in stainless steel. The fact that it conducts heat doesn't matter, it'll solve the cosmetic problem, which is your concern.
prv
29 Nov 2009
Southampton
Stainless sheet, spaced slightly off the wood by slipping a nut or a stack of washers over the screws between the metal and the wood.
I don't understand why it's such a "hell of a job" to move the pivot points up a few inches though.
Is the lower cooker still ok when heeled fully over in the direction that swings the bottom towards you? It might move freely, but will it put the burners under the worktop behind it?
Plum
6 Jun 2001
UK East Coast
Any ideas?
Andrew
Stainless 1mm thick or more screwed on with 3 or 4mm spacer washer at each screw to allow airflow between steel and teak edging.
Www.solocoastalsailing.co.uk
TLouth7
24 Sep 2016
Edinburgh
I would think that a metal shield should reflect radiant heat effectively without getting so hot as to burn the wood behind it.
You could chop up a silicone oven tray/heatproof mat and either secure it directly over the trim, or sandwich it behind a metal heat shield.
KenMcCulloch
22 Apr 2007
Edinburgh, Scotland
Stainless steel sheet does two things when you use it as a heat shield like this. It is very reflective which is the first thing. The second is that it conducts heat, so you don’t get such high temperatures as to scorch the wood. The heat spreads across the metal sheet so the temperature at the hottest part is lower than otherwise.
DownWest
25 Dec 2007
S.W. France
Stainless does not conduct quite so well as plain old steel, so the reflectve bit and a layer of insulation behind it (glass wood stove tape from B&Q?) should do it. An actual insulation is better that just air, as it stops radiant heat that will eventually dry out the woos and could cause spontanious combustion. Pretty unlikely with a galley stove, more a problem with a cabin heater like a coal/wood/charcoal unit.
ghostlymoron
9 Apr 2005
Shropshire
I think you would do better by raising the gimbals so that the stove is at the correct height relative to the work top. In my limited experience, the sides of adjacent cupboards are protected by thin stainless sheet and nothing else. I've never looked underneath it so don't know if the wood has deteriorated but it hasn't caught fire. Stove installation instructions usually stipulate an air gap between it and the adjacent woodwork.
Apologies if I have misunderstood your problem. As someone else said, a picture would be helpful.
PetiteFleur
29 Feb 2008
Suffolk
When I put a new Nelson stove in my boat to replace a Vanessa, I raised the gimbals up which meant I gained a space below, for which I made a drawer. I did have to cut slots in the teak trim at the top for the gimbal fittings but it looked fine when finished.
