Trident
So motoring my new to me catamaran up the solent she was impressively slow. She has two Yanmar 3GM30 engines and at 2500 rpm on both would only make 5 knots (and down to 4 against the solent currents). She has SD20 sail drives and currently 16/12 three bladed props which is what Yanmar recommend. She is 50 foot and only around 9 tonnes and the manufacturers blurb suggests 10 knots under engine, though that was with a shaft drive not sail drive. (Bottom was relatively clean, engines working ok etc) - so I was looking at the props - my last boat was also a cat and had a single sillette drive but the same prop and same gear ratio . She was also slow until I changed (against the advice of Sillette ) to a 16/14 and then she would push in to wind and seas like never before and make 2 knots more in flat calm.
Is there likely to be any issue with doing the same with the Yanmar sail drives? Its very firm about not going bigger (and I could fit a 17 inch but I guess they say no more than 16 for a good reason?) and strongly recommends the pitch I have now but could I really harm it if I change.
Sadly none of the prop calc software is designed for cats so getting a definitive answer on size and pitch is difficult - hence hoping for some more expert opinions on here
