Prop
Micky
27 Sep 2004
UK
Looking for a 2nd hand sail drive prop to fit my Mercury 8hp, 1998/9 model outboard, or can anyone tell the price for a new one. Many thanks for any help/info.
snowleopard
Oxford
to clarify- you plan to fit a prop designed for a saildrive onto an outboard?
do you have reason to suppose this would work? i would expect the hub diameter and pitch to be wrong and the prop diameter to big to fit under the cavitation plate, do you know different?
William_H
28 Jul 2003
West Australia
Another way to describe what you want is a finer pitch possibly 3 blade prop for your O/B to use on a lower speed displacement hull (yacht). You perhaps should go to a dealer and find if there ever was one available. Unless you have a real problem of getting enough thrust into a strong headwind it may not help you much and will increase revs and noise for a given boat speed. It will not help much against a contrary tide as you are trying to overcome displacement hull speed limitations. regards will
