SimonD
I've got a bit of vibration (after having the engine alignment adjusted at the start of the season) and am taking the opportunity to check everything before considering a flexible coupling.
Darglow checked the balance and pitch of the prop (highly recommended by the way - did while I waited at no charge). Now I want to check the shaft straightness. I'm planning to take it to a local machine shop. The shaft is 1" diameter and 55" long. What's the maximum permissible run out?
