SimonD
It can also be that the hole is not central in the coupling. Try the broomstick method (carefully!) or better use a dial gauge, but move it as far forward as possible, then as far aft for comparison. Sometimes moving the coupling round 90 degrees on its bolts will help.
Thanks Vyv. I've never heard of the hole not being centred. If I could get some sensible indication of 'wobble' I could then, as you say, move the coupling 90 degrees and compare measurements. As the boat is out of the water, this measurement will have to be done by rotating the shaft manually. That said, it should give the same result.
Whilst we're delving into this, I should mention that the shaft looks central in the cutlass bearing, but certainly not central in the stern tube (when viewed from the outside). It looks closer to the port side of the tube than the starboard, but central at top and bottom. I'll need to look at the shaft as it exits the stern tube on the inside when I've removed the gland seal. If it's not central, I'm not sure where to go next. The implication that the engine needs to move to starboard is too awful to contemplate! Some means of checking the shaft is concentric with the coupling would be handy, but I'll check the shaft runout first.
