Tranona
What size is your prop shaft? The seals are made in both metric and imperial sizes and they are not interchangeable. For example if you have a 1 1/4" shaft the metric "equivalent" is 30mm which may just slide on but will be too tight. Does the shaft turn freely when not in gear? Also although you have checked there is no air in the system when static, have you checked that water can flow out of the aft end of the stern tube?So I replaced with a new transparent hose and ran it above the water line. Before I fixed it I let a few litres of water out making sure there is no air left.
After one hour of motoring the edge was again ~70-75 degrees C, the body about 40. So there is no change.
The temperature did not continue to climb past that mark. Next I will try to run forced cooling either from the cooling water from the engine, or just a small 12v pump with a fresh, cold sea water and see how it changes things..
