calloo
My boat is conventially shaped long keel with transom hung rudder. The shaft from the propeller goes through a white metal bearing, I assume to be about 6 ins long. Then there is a cavity through the hull of approximately 14 inches, then the stuffing box which has a screw down grease cap. The stuffing has not been touched for 25 years but does not leak so I have left it alone. My question is - does the grease injected by the screw cap permiate from the stuffing box down the cavity to the white metal bearing or does it merely lubricate the stuffing box area leaving the white metal bearing to be lubricated by sea water? Further more can any body advise me on the best type of grease for the purpose please?
