Graham_Wright
Apart from crevice corrosion and galling (as if they weren't enough) why not?
I can make one of those M24 X 2 in 1.4404/316.
Galling is a serious reason why not. Galling is a high temperature mechanism that is effectively welding and parts galled together are immovable. As if getting a prop off is not difficult enough in some circumstances, having to cut the nut off without damaging the shaft or the prop would be a step too far. Why not make it in brass? Most are nowadays and they last at least ten years.
I have experience of galling both in parts manufacture and on the boat. I would not restrict it to high temperature though. I had to grind off the chain plate nuts! The trick explained to me by one of my (very experienced) staff, is to tap around the periphery of the nut (in our case ring) while attempting to rotate it.
It is a high temperature mechanism but that does not mean it only occurs when it is hot. Localised welding takes place between the microscopic high points on the two surfaces, due to the load, not the temperature.
www.lakesterngear.co.uk will supply a nut - as will any prop or stern gear specialist. £34+VAT in their catalogue.
Thanks for the steer. However, they have this morning told me that their nuts are made of Navel (sic!) brass which has an even higher zinc content than other high zinc brasses.
Am I missing a trick? How can it claim to be corrosion resistant?
See post#3. Those nuts seem to be satisfactory and have been in use for many, many years. Pretty sure that if they were not then they would have been discontinued a long time ago.
Naval brass is 60/40 copper zinc with about 1% of tin added. Slightly better corrosion resistance, but as I said above, ordinary 60/40 brass will give you 10 years so for a low cost item is perfectly OK.
I've looked at the horror pictures on your website. I don't think low cost is an overriding factor!
If the prop falls off in difficult circumstances, it could be life-threatening.
Plenty of other things to worry about!
……like brass hull valves?
After all these comments, it seems we should be happy using brass fittings on board.
We have all seen corroded hull fittings, I have experienced brass screws turned to copper (and that was out of the water).
Despite this we are urged to use anything but brass under water (except for prop nuts!).
Baffled!![]()
