Hacker
Had Perla, our Channel Island 32, lifted out on Friday foe 2 weeks to antifoul, varnish the spray rail and change the anodes. Had a nasty shock when I went to clean the port prop, it had been attacked! All 3 blades have pitting on the surface and damage to the edges. No such damage apparent on the stb prop, both rudders, both P brackets and both shafts (although still to grind the crap off them. Pictures from her survey last August show the prop is fine.
Current view is either that I have a ground fault on my charger or a neighbouring boat has an issue. If the former then I would have expected the damage to be spread across the other bits. The neighbouring boat is moored on my port side and appears to be built from steel.
Does anyone have any further thoughts? I’m trying to get a local marine electrician to have an initial look.
