Problems with ICOM VHF charging
Oscarpop
31 Jul 2011
Kent
I purchased an ICOM VHF radio second hand. It worked perfectly, now it is refusing to charge and I am trying to work out what component is faulty.
The radio sits in its desktop cradle and connects with the contacts in the cradle. the plug from the charger then plugs into the cradle. Now the thing is refusing to work . If i "wiggle" the lead into the cradle, the charge light may occasionally come on, however this really is a hit and miss affair.
Suggestions please? I am unable to bypass the cradle either.
Many thanks.
EdWingfield
10 Apr 2006
Campbeltown
I had exactly this symptom.
Feel the electrical contacts with your nail. You may find a tiny 'pip' that causes a poor connection. Remove the pip with a nail file and you should be ok.
coromar
15 Dec 2004
Icom charging
Hi,
With my Icom I can take the battery out of the radio and just charge that. The charger unit fits the battery.
Have you checked the contacts on the radio for charging, mine needed a rub with wet and dry paper.
Best of luck,
Paul
rob2
23 Aug 2005
Hampshire UK
I'd be cautious about using abrasives on the contacts. I used to clean edge connectors on printed circuit boards by rubbing them with an eraser. Iso Propyl Alcohol is also good at cleaning a lot of verdigris off without risk to surrounding plastic bits.
Rob.
PeterGibbs
3 Sep 2001
N London, and boat in Suffolk
Many thanks.
Rechargeable, smargeable - heave out the decaying recharge batteries and replace with Duracell - no more problems. And a radio that works. It's what I did. Never looked back.
PWG
Talulah
27 Feb 2004
West London/Gosport
PWG
With some Icoms the power output is less when using the alkaline battery pack instead of the rechargeale pack. i.e. 2W instead of 6W on an M35.
noelex
2 Jul 2005
Its common for the thin wires to break internally near the end of the plug and this sounds like the problem.
The plugs are often standard and can be purchased at one of the electronic shops. Alternatively open the case and solder the wires directly to the plug socket leads, leaving the wire permanently connected.
Oscarpop
31 Jul 2011
Kent
I don't think it is the contacts. it does sound like a problem with the wires in the lead to the charger. I will investigate further.
Conachair
24 Jan 2004
London
Worth checking out the contacts first though. I had the same with an m71, emailed icom, quickly they emailed back and said, common problem, clean the contacts. From memory the charger was flashing green. Working fine now.
