aussi
Hi All,
I've got an issue with my Penta, and was wondering whether someone can help.
Firstly, the history: It's a new boat (to me), 1991 with original Penta 2003T. Since taking ownership I've had the engine serviced, and it also had an overheating problem so the cooling system was overhauled which included a new oil cooler unit. It runs with a bit of white smoke, but not enough to worry me too much. I also had a problem with the engine stopping after some time running, which I put down to fuel contamination so I changed the fine filter which has solved the problem for now - I'm keeping plenty of filters on board and will also be cleaning the tank this winter.
Now, the problem: It happens when I run the engine for an hour or so to get out of the river (cold start), then go sailing for a few hours, then run the engine again (i.e. warm start). The second time, I get quite variable engine revs which lasts for some time. Also, I can't rev the engine above about 2000 RPM (full throttle gives about 2000 - 2200) during this period. It doesn't stop completely, but is certainly not able to give me full power. After about 30-40 minutes it seems to gradually recover, but I haven't been able to do extensive testing for longer than this because I'm always back on the mooring by then!
If anyone has any ideas and/or solutions, I would be very grateful.
Regards,
Austin.
Regards,
Austin.
