PembrokeshirePromise
Just bolted this all in at the w/e (note new winch)
Connected up the cables today. Fed in the chain.
Up and down work - but only briefly - c 10 seconds or so /forums/images/graemlins/frown.gif
Then sounds like the solenoid is clicking in and out a few times - then fuse blows on switch line (5 amp) and solenoid cables get slightly warm
Testing on a new battery reading c. 12.5v - engine not running as on the hard at the mo
Seems to me the winch might be running a bit slowly (especially in down mode) - but as I've never seen it working I don't know what to expect
Seems to me I must have wired everything up OK - as it works - all be it briefly
Running slow would suggest not enough power - but all connections look good
What I don't understand is why the solenoid fuse blows - electrician suggested that that would be symptomatic of a solenoid coil that was failing - perhaps shorting out part way through the coil - hence voltage dropping and its drawing more current ??
Before I unbolt it and send the whole thing back (grr) - I've put the battery on charge to be double sure and I'll give it one more go.
Theres no chance that 12.5 volts is on the edge of closing the solenoid - and so as power is drawn from the battery it starts to "flutter" - clutching at straws really here ...
Anything I'm missing ?
James
James
