joliette
My topping lift is currently rigged through a block at the masthead, whereas it should pass through the sheave that is fitted at the masthead and down through the mast. I am planning to fix this by using the main halyard to pull a messenger down through the mast (having passed the messenger over the topping lift sheave out through the main hayard sheave and secured it to the main halyard). Once the messenger is out through the main halyard exit slot at the base of the mast I can use this to pull a new topping lift through the mast and out through the correct sheave at the masthead. However, the exit slot for the topping lift is on the opposite side of the base of the mast, so I guess I'll need to fiddle about with some wire to try and hook the new topping lift through. Does anyone have any experience of dealing with this problem? Any tips would be much appreciated. Thanks.
