SolentPhill
Well its good to be back on the water everything worked fine before the winter, so they say everything comes in 3's and i ve got my 3. VolvoPaul all being well will fix one issue, then i need assistance with the other 2 issues and to save confusion i will make 2 threads.
Im not sure exactly how the vacuum pump system works as its one of those things that works and that's it, i've never had a need to look too deep. In the locker where the waste tank is i have a pump that pumps out to sea, i have the white small tank with a motor on the top. when you press the pedal to flush the toilet the ball opens and nothing else apart from fresh water coming in, then you hear the noise of the motor running that always runs after you flush and stops usually after 15 seconds and then you can flush the toilet again. whats happening now is the motor runs and does not stop, there is a pressure switch that works fine as i pushed it and the pump stops. I am using common sense and presume the motor extinguishes all the air and when all air gone the motor stops and then you should be able to flush the toilet, so if the motor is constantly running air is getting in the system. is there a quick fix or a seal kit and where should i be looking?
I have enclosed a picture of it.
any help would be good
