oceanfroggie
Hope not too much damage was done...
http://metro.co.uk/2014/03/16/river...est-london-despite-the-great-weather-4608626/
I feel for him. What a shame.
So what's the answer?
How about turning round before the bridge, and reversing through with the engines going forward?
That would give him time to stem the flow and inch through very slowly.
Or am I missing something?
Its a 67 as in one in the photos shows it written on the radar arch.
http://www.huffingtonpost.co.uk/201...nto-richmond-bridge_n_4975357.html?1394991943
It made me cringe hearing the crunching fibreglass. If only he'd carried on astern for another 30 seconds before trying to turn he might have got away with it.
When he is broadside to the bridge and pinned against it, would bow and stern thrusters have been powerful enough to push him off alone?
In video 1 as he was backing out - I wonder did he see the small boat astern of him and stop going astern for fear of hitting the small boat?
Most probably not.
Being pinned to something solid by a moderate current would be an extremely difficult situation to extract yourself from without causing substantial damage.
Most probably not.
The thrusters on our P67 can just about hold us parallel to the wind in a F5 but ours are upgraded ones (bit more powerful than the standards ones)
So, in this case, IMO after he had pinned himself sideways against the bridge, going hard on both thrusters for a good 30 secs should have got him well clear.
But the key would be to have kept the stern into the current all the time and "crab" the across the river.
Do you mean "parallel to the wind" or "perpendicular to the wind"? I wonder how the force of a F5 wind on that topsides profile compares to the force of a (say) 4kt current? Any idea/guess on that.
I mean sideways into the wind
On slack water with no wind a 3o sec squirt of both thrusters should move the boat a couple of boat lengths and once moving, the momentum should keep her going for a further two lengths.
30 seconds is a good squirt - if I was going to use the thruster for this kind of thing, I would really use then with assertion.
A boat like that is close to 50 tons so getting it moving sideways through the water takes a good blast of the thrusters - no point "tickling them"
Yes agreed and rule #1 when turning is to give yourself plenty of turning room.I doubt you'd be able to go over 4 knots sideways on just your thrusters Mike? Also, if the river is flowing 4 knots, it'll be quite a lot faster through the arches and around the bridge supports. Once he's pinned there, I think he either needs towing off, or will be washed through the arches, as eventually happened.
He was initially going through fine, but obviously decided there wasn't enough height. As others have said, the problem started when he didn't reverse far enough upstream before he tried to turn
