Princess crashes into Richmond Bridge
boatone
29 Jul 2001
Just a few cables from Boulters Lock
www.tmba.org.uk
I'm confused: why would the water level rise so rapidly with no rain falling?
Dunno what the tide state was but Richmond is below Teddington and, although there is a half tide barrier to prevent the level from falling too low, it can, and does rise very high. At high spring tides it can actually flow upriver over the weir at Teddington and the river becomes tidal up to Hampton Court.
Ramage
9 Jul 2006
Hampton Hill
High Tide at Richmond today was 14.44 ft at 14.57. The previous low tide was 1.31 feet at 09.57. At 23.07 tonight the low tide will be 1.97 feet.
Lots of people get taken unawares by the tides at Richmond!
D
Deleted User YDKXO
Combination of near Spring tide and a fast flowing river? As somebody who has clouted a bridge with my boat, this fellow has my utmost sympathy
Observer
21 Nov 2002
Bucks
Two videos on YouTube
http://youtu.be/PIiXndllxIQ
http://youtu.be/GulYaobJgVI
Judging by the soundtrack, I'd say that was a very expensive lesson in boat handling - particularly the need to think about how you get out of a situation before you head into it.
I wonder what the experience of the skipper is. Not much judging by what were some basic errors, although the pressure on him must have been near overwhelming.
Fundamentally of course the mistake was getting that boat anywhere near that bridge in those conditions. He got through in the end but I suggest more by luck than being in control. I can't see how to shoot those arches going downstream at anything less than (say) 4kts through the water, which would be minimum 8kts over the ground? What speed is a boat like that making with both engines in gear at idle speed? 5kts?
longjohnsilver
30 May 2001
It made me cringe hearing the crunching fibreglass. If only he'd carried on astern for another 30 seconds before trying to turn he might have got away with it.
lovezoo
23 Feb 2005
Citta del Vaticano
www.myspace.com
In fairness, I think most people wouldn't understand how much damage would be caused.
Or care. There are several pubs around there, and they would be crowded with people on a Sunday afternoon. The sport is normally watching cars that are parked by the river getting flooded, so a big boat getting stuck would be a huge bonus.
Skinner56
16 Mar 2014
Humiliating experience.
I am very experienced but mostly at sea, but not so with dealing with a rivers tidal flows.
The yacht makes 5 Kts over SOG with both engines in gear, though from Teddington to Richmond the boats port or stbd engines were only engaged, fwd and astern, to keep her positioned.
The necessary tidal height calculations were completed and a phone call to the PLA boys in the area informed me that I should expect and increase of half a metre on listed tidal heights, this was also taken into consideration. As you could see once I had extracted myself from the bridge I squeezed through as with enough headway backing up my initial precaluculations.
The problem I encountered was aligning the yacht up to the centre line of the arch as the arch has rather steep drop offs from the centre line. Once astern thrust had been engaged, the strong tidal flow started to push the stern to the starboard rather rapidly. This caught me unawares as the yacht obviously has a lot of power to hand, but not enough to stem the tide.
I've certainly learnt a harsh lesson in coping with strong tidal currents, and narrow bridge arches.
Skinner56
16 Mar 2014
I soon as I went astern the tide caught the stern and pushed it to starboard, took me completely by surprise the strength of the flow
peterandjeanette
11 Jun 2001
Stratford upon Avon/Sant Carles
So what's the answer?
How about turning round before the bridge, and reversing through with the engines going forward?
That would give him time to stem the flow and inch through very slowly.
Or am I missing something?
nimbusgb
22 Oct 2005
A long way from my boat! :(
www.umfundi.com
I'm no motor boater but with that flow even I would say keeping the pointy bit upstream and almost 'ferry gliding' backwards through the bridge would be the way I'd approach it! Goosing the throttles in forward on that beast would get you out of the danger zone pretty sharpish I reckon.
