Princess 35 with mermaids
Amour
28 May 2015
Hi on our princess 35 on the lower Dashboard there is a change over switch for the gauges on flybridge the switch is getting dodge can I bypass it and connect up so both sets of gauges are working at once ??
Sorry no you can't. The sensors are calibrated for one gauge per engiñe. Have you tried contact cleaner on the switch assembly?
The main oil pressure and water temp sensors are VDO , which are in there on line catalogue you would only need the thread size for the oil pressure and temp sender , you could then have them running together, this is what Volvo have done for years.
