Joachim
New Member
I'm considering buying this boat. Who can share experiences regarding quality, fuel consumption and overall performance?
Joachim
Joachim
JoachimI'm considering buying this boat. Who can share experiences regarding quality, fuel consumption and overall performance?
Joachim
The hull is cored, and the laminate thicknesses either side of the core were thin. Even if the core had been executed perfectly the two laminates were too thin for me to be comfortale with the boat, but alas the coring was not done correctly. The adhesive (brick red colour) appeared to have been applied to the inside of the hull with a trowel with grooves in it, and the "ridges" of adhesive formed by the trowel were perfectly shaped in many places, ie the core had never touched them, let alone bonded to them.
I came accross an interesting investigation report about an incident with a new Prestige 42S which drives collided with a shoal in May 2010. The IPS500, didn't fell off but ruptured the transom and the boat sank in roughly 12 minutes. The report states (pics on p. 13) that the thickness of the transom was 8mm. (1.5mm. fiberglass + 5mm. core + 1.5mm. fiberglass): http://www.turvallisuustutkinta.fi/...tion&ssbinary=true&blobheader=application/pdf
Overall, the investigators don't mince their words about the causes of the incident:
"The drive unit did not break off in a controlled way so that the hull of the boat would have remained watertight, but instead the impact caused by the collision broke the weakly-constructed hull of the boat."
"The construction of Jeanneau Prestige 42S was found to be weak at the joint between the transom and the bottom, and the joint of the IPS drive unit and hull carelessly and poorly completed"
This also raises interesting questions whether such drives are really designed to "fell off" in case of a grounding? The report mentions another incident with similar IPS issues, while Volvo Penta in its statement at the end of the report says it works "in most cases of grounding"...
Oh yes, it may well do. But that isn't the point: my comments are about the jeanneau GRP quality generally in the 2 boats I saw, and in the Finland sunk boat, and i think that quality will cause problems even if you don't smash into a rock as hard as Mr Finland did, or at all. Hence I'm suggesting to OP he gets the princess 56 out of the two boats he listed. All imhoI was going to ask:
If you hit a reef with a shaft drive boat, it's still going to rip the shafts out and punch the p brackets through the hull with the same end result no?
Kieron, the degree of protrusion with an IPS is significantly more than that of a shaft drive, so the risk level increases as a consequence.I was going to ask:
I was going to ask:
Who is Kieron?
Who is Kieron?
Great post. I think it shows the maze that people consider on buying a boat.Hi Joachim,
I am have this exact same model being built now for delivery to Canet-en-Roussillon at the end of May. I can give you no feedback yet on fuel consumption or performance, but I can give you the reasons why I chose this make and model above the Princess 56.
In my opinion there is no doubt that the build finish and materials used on the Princess are of a definitely higher quality than those found on the Prestige, and indeed I have stated directly to the senior Prestige management that they need to up their game in that area if they want to make further inroads into the luxury high-end market. But ultimately on that point I decided that - from my perspective - it was like buying a top of the range Ford against an Audi/Mercedes... ultimately they are all just cars that get from A to B in a similar fashion. And already at the top end of my budget, that the 25% additional cost of the Princess did not overcome the other substantial plus points of the Prestige against the Princess. The main ones being the exterior styling, the design and layout of the internal spaces, and the pod drives. Aesthetically I love the look of the 550 which I find very contemporary, not a design that will seem dated anytime soon. Whereas the Princess I found a little more conservative and one which could perhaps seem yesterday's design in a few years time. I also really preferred the Prestige owner's cabin, with its separate entrance, walk-in wardrobe, shower etc. And I loved the saloon area, with its vast windows. My wife and I both felt that this was a boat that we would really enjoy living on. Finally, as a beginner to sailing, the clincher was the extra control that the pod drive's seem to offer.
Whether or not this boat will age as well as the Princess, with the wear and tear of usage, we will find out over the years to come!
Mark
