GaryBmth
New Member
Hi everyone, thank you for reading. Due to ill health & COVID, our Sun Odyssey's Volvo 19hp inboard hasn't been started for several years but I'm now able to do a lot more again thankfully so am preparing to get it running again.
I've put a new impeller in and thoroughly cleaned/polished the cover. I've emptied the old fuel from the tank completely so it's bone dry and very clean (it was a little bit yuk in the bottom but not awful, possibly just sediment).
I've made a list of things I think I should look at. I'm pretty sure I've got a workshop manual somewhere and I've got tools and am fairly mechanically minded, just don't have a huge amount of boat or diesel experience.
My list so far is as follows, in no particular order. If anyone has any ideas, tips, thoughts, warnings or spots anything missing, I'd be very grateful...
Check air filter (probably replacing with K&N washable as old one has fallen apart).
Check exhaust elbow to make sure it's not coked up or blocked, if I can get to it and get it apart?
Check propshaft joint, is the sea seal where you squeeze it to let some sea water in to lubricate it perished or gone hard & does it need replacing, hopefully not. Should I spray it with silicone lubricant?
Fill with new fuel, can I get original non plant based additive fuel to avoid bug or just use additive and not worry?
Look at how to bleed the diesel through to ensure no air in the fuel system.
Change oil and filter.
Look at how I could lubricate cylinders, with oil or wd40 or mix of both, to protect the rings and bored
Do I need to remove and check or replace injectors?
Lubricate anything that moves, like throttle related assemblies
Should I spray belts for water pump etc or will that just make it slip or should I replace it (it looks ok from just looking at it but might need a closer inspection)
Manually turn engine first a few times (spanner/lever on the crankshaft/fan pulley?) to check everything is free and moving.
I read in another post to check the valves and springs haven't got stuck so they don't hit the pistons. Can I just do this with the covers off and manually turning or do I need to do any disassembly of anything do you think)
Many thanks
Gary
Bournemouth
Many thanks
Gary
Bournemouth
