5teve
In our never ending quest for a larger boat, given limited budget and limited availability here in Perth, Australia we seemed to have narrowed our selection down to 2 boats - they are both from the same local manufacturer and are both 33ft - but actually just shy of 37ft - but that is where the similarity ends. - different layout, engine, fittings etc etc.. if we could combine the 2... perfect! but we cant so its going to be a case of best value, best compromise and what we deem may be less trouble overall.
So we went for a second viewing on Boat 1 - 2002 - Iveco powered - better original fitout - 2 cabins (which is both good and bad as the vee is smaller and saloon area is smaller) we went over it with a fine tooth comb and its obvious in areas that lack of use has set in -
Winch housing (under deck) is white and furry - anchor chain isnt much better!
Engine frame galvanising is flaking at the water pump end of the engine (I think there may have been a leak) but its a solid frame so not really a worry..
Rudder gland is pretty rusted up (steering is still very light) so will need cleaning / replacing and is weeping a bit.
Tank water smells apparently - I'll assume a good clean and change of pipes may resolve this?
Oil leak - coming from an unidentified part at the gearbox end of the engine via what looks to be a weeping banjo fitting. Doesnt look too serious - but looks like its been doing it a while.
The one that really bothers me is the racor filter - its a single turbine version as per http://ph.parker.com/us/17583/en/fuel-filter-water-separator-turbine-series - and the glass bowl is full of what looks to be algae. I'll also assume due to lack of use and fuel treatment the 2x fuel tanks are likely to be pretty dirty internally - what are my options for:-
Cleaning the tanks (not sure of access at top)
Cleaning the existing fuel - without removing 3-400l off the boat (its on a swing mooring)
probability of fuel filters being ruined?
I'm thinking if I can shut the tanks off from each other i could pump from one into the other filtering as I go, to empty the tank - see if I can clean the empty tank and then do vice versa - does that sound reasonable and what sort of system could I use for filtering the fuel?
Any other ideas would be gratefully received!
Steve
Steve
