Refueler
Yanmar 2GM20 to shaft .... unfortunately - to see the shaft would be a contortionists nightmare and I value my health !!
I have two 'plastic' reservoirs fitted above engine to companionway bulkhead ... larger looks like a pressure expansion for calorofier - removed by previous owner - but piping still in place (valves closed of course).
The smaller bottle bottom left - we believe is the oil feed to the shaft seal ...
I do not have information as to what seal is fitted and therefore its pot luck on what oil to use in the system. As can be seen its low and actually its been like that since buying the boat - only moved a few mm maybe a cm.
Online I read that ATF .. Low Visc Oil ... Engine Oil .... EAl - are possibilities ..........
Because I was checking the engine oil - I had the 5W 40 at hand and decided - give the feeder a top up ... it appears that the oil that was in bottom of the feeder was likely ATF as it has stayed separate to the darker engine oil.
I have a boat trip spanning ~ 4 days and engine will be run for short times ... berthing / unberthing ... probably about 6hrs in total ... therefore given the miniscule amount the feeder moves - the ATF will still be at bottom of bottle.
Deciding whether worth syphoning out the 5W40 after the trip and refilling with ATF .. or just leave it .. assuming it is ATF .. not just light machine oil...
