Our P40 has a polarity indicator (Polarity correct when lit) on the main switch panel, which has a burnt out bulb. I want to replace this unit.
Am I correct in assuming this is 240v polarity?
AC doesn't have "polarity".
@halcyon, on the Princess 40 the indicator is connected the other way round from your description. The neon lights only when the polarity is correct. Read the label next to the neon on the OP's photo. This is also the case on my P40.
@sprocker, as others have said and as I can see in the photo, it's a neon bulb with a resistor soldered in series in the tail leads. Neon bulbs tend to flicker for a long time before they eventually fail. If this one failed suddenly it might be worth checking the resistor and connections.
LED?
Thank you Bruce...that is definitely the quickest fix I ever had here.
Even more amazing, I Googled whether LEDs work with reversed polarity, found an old bike light and answered my own question, before I'd read your reply! :biggrin-new:
Incredible...I spent 50 minutes on Youtube looking for a way to detect polarity, and there's not one instance of this simple solution.
Bear in mind a multimeter can be had for £5 or less on eBay and is a useful thing to have
If you dont have a handy LED or only one that works both ways....
Wire the unknown supply in series with a battery. The right way round will light a lamp (brightly), the wrong way round wont (much).
