yachcting monthly this month mentions succesfully polishing out crazing in deck hatches-can anyone tell me what sort of polish to use as both my hatches are crazing-thanks?
There comes a point in the crazing where both sides of the hatch are crazed and the crazing goes a certain depth on ewach side. This is when the hatch starts to leak!! and probably is unsafe to walk on. Eagle Boat Windows refurbish portholes and from what I 've seen do a good job.
toothpaste worked wonders on my dull and scratched compass - would have thought that crazing on a hatch was actually cracks rather than scratches - wont polish out
read the article is what i said!
the rep pulled a crazed hatch out and got the reporter to look thru it sideways, the crazing,quote is only about 1/2 a mill or in old money, 20 thou.
It would take quite a lot of polishing to remove 1/2 a millimetre of acrylic. Surface scuffs and minor scratches which obscure vision may be succesfully removed. I have had success with Auto Glym paint renovator. The surface came up like new. I used a foam pad on a Black and Decker orbital sander which worked quite quickly. Crazing however was not removed so I replaced the acrylic and found in doing so that it was easily broken and a good deal weaker than the new material.
Scratches and sharp corners in various materials can be a source for cracks to start which lead to failure. Crazed acrylic requires replacement for safety as well as aesthetic reasons.
I've had success with Brasso. If the crazing is too bad to respond to polishing you might consider coarse sanding which gives an opaque but uniform finish. A bit like a bathroom window! I've seen it done very successfully.
you'll naturally be using some sort of machine - hire something or a mop for a drill might be ok. Jewellers rouge would do it, I think- get it mailorder. Most sensible schools have a stick of 'soap' for buffing acrylic around somwewhere; its lasts for ages nowadays cos theres so little practical work done. Try to find a friend of a friend or similar who's a technology teacher or technician and borrow somw for a weekend.
Hi, you've said "read the article" several times but I suppose I am not alone in not having access to it, not being in the UK and not having a permanent address, so can't subscribe to the mag. Is the article online, perhaps?
I don't have to read an article to know that if a plastic hatch is crazed over its likely to be to deep to polish out! Iv'e been boating far too long, its a short cut measure that will not last! replace the thing, its not that difficult!
