PabloPicasso
What plotters can gave an additional repeater added? So main plotter at chart table with a repeat display at the helm?
Or is there an easier way of doing this?
Still prefer my Yeoman though as i found trying to plan a course with the plotter difficult without a full sized chart. As one zooms out to see the overall route one looses the depths & buoys etc so it means zooming in, scrolling round to find a particular buoy,( or feature) putting in a waypoint then repeating for the next point.
If you are thinking of buying one then as an example when you look at it try plotting a night route at low tide from the gates of Grimsby lock to lowestoft. It takes ages in the Humber & just as long plotting through the Scroby sands to lowestoft
The new raymarine ones have the ability to completely replicate themselves on an ipad. Put the waterproof plotter in the cockpit and use the ipad at the chart table. Or loafing in the saloon. Or in your bunk if off watch but want to keep an eye.....
We have our chart plotter installed in the saloon and unless you can install it in your cockpit where you can both access charts and someone independent from helmsman can do navigation, I would not change it. [...] A chart plotter behind the steering wheel is nice for calm weather sailing
but when there's a blow, it's in the middle of the night and your navigating coast in tides someone will need to do navigation downstairs anyway... Where a plotter would be v handy at that point
We have our chart plotter installed in the saloon and unless you can install it in your cockpit where you can both access charts and someone independent from helmsman can do navigation, I would not change it. Or if you're single hander maybe. We then have a pad /smart phone with navionics in the cockpit for 'emergency'. A chart plotter behind the steering wheel is nice for calm weather sailing but when there's a blow, it's in the middle of the night and your navigating coast in tides someone will need to do navigation downstairs anyway... Where a plotter would be v handy at that point
Edit :need to point out that we do navigation on paper charts for 90% of the time, something about it...
We already had a good sized plotter/radar above the nav' desk when we bought the boat but we now rarely use that.
I bought a Standard Horizon 300i which has mounts and cable connections both under the spray hood at the back of the nav' desk.
The SH plotters are reasonably waterproof and easy to connect and disconnect plugs from sockets each time.
We often passage plan on a paper chart sitting inside in comfort at the nav' desk.
I usually put in 'marks' or waypoints on the plotter at the same time to keep me suitably on track next day.
(applies equally to johnalison)
So you can't see the radar from the helm? I see that a waste of one of the most useful navigational tools.
Someone will need to do navigation, but why do they need to be downstairs? Under the sprayhood where they can talk to the helmsman, see out, stand up and take a bearing on a light, etc - that makes far more sense to me.
I have my Raymarine plotter at the chart table - but only because of the difficulty of running all the different cables up the skinny tubes of my pedestal. I would move it up to the helm in a shot if I could do it without making major modifications.
As others have said, iPAd wifi link is great - but iPad is better used inside (even in a waterproof case) as it is not sunlight readable.
Shame Raymarine don't make one of their A-series plotter repeaters with a wifi-link, then I could put that at the helm.
You would still need to get power to an A series. If it is a slave unit plotter you only need power plus an ethernet cable for full functionality. Could you do that?
