Sarathlal
New Member
Can anyone tell me..... why a stainless steel prop found corroded but the drive aluminium found verymuch new.....is it a material defect?????
Cavitation? Stainless props are used to reduce it.
Yup, it may well be cavitation. Esp if the pitting is close to the hub rather than the tips. Needs fixing. Can you post pics?
This is a duoprop of Volvo D3 AQ & its hardly 1.5 year old......the prop came as a complete assembly...its manufacture supplied with engine & drive.
Tricky one. The localised pitting is normally cavitation (and, incidentally, I woudn't fully agree Portofino's description of it from a fluid mechanics pov but that's neither here nor there) but in this casePFA for the pics.....
I suspect it's as simple as that.is it a material defect?????
Cavitation is the introduction of air adjacent to a foil or other body moving through water. It can come from the surface - or in this case from low pressure zones caused by the movement of the prop blades through the water. The water will boil, just like in a kettle if the pressure is reduced far enough. The continuous exploding of gas into the water against the surface of the prop is very powerful, and erosion is severe and fast. The props may be turning too fast for their design, they may have turbulence issues or any number of things going on. Prop design is seriously complicated stuff - even the best designers in the world will admit that they are working in a very grey area of physics that confound the best super-computers in the world. The fact is that the actual way subsurface propellers work is only partly known - there are forums out there with some of the best naval architects in the world debating incredible concepts and writing new software every month to try and get better performance and life from propellers. The calculations fall apart in most cases because you can't go too big or too slow - the bigger you go and the slower you turn the better the prop, but this quickly runs out of reality if the software tells you a 200 meter blade is most efficient at 0.3 rpm!!
Why not, J?I woudn't fully agree Portofino's description of it from a fluid mechanics pov
Why not, J?
He obviously has a deep knowledge of the subject, garnered from an extremely reliable source (scroll down to "best answer")...![]()
LOL, that's actually not so difficult, nowadays.Tee hee. Your specialism must be finding needles in haystacks!
Of course, as we all know, getting VP's warranty department to agree will be a pointless waste of OP's life; better to send props to www.SteelDevelopments.net for a £250 repair.![]()
These DPS props are not protected by the anodes, the stainless part is isolated by a plastic bush. It's crevice corrosion, If you poke at the holes you'll find a track to the plastic bush between the aluminium hub and the prop.amd probably a lot of other hole in the vicinity of the bush.
I've had this on my DPS props; never on the blades wihich are always exposed to oxygen, In the first case, after one season a small rust spot was found which when poked, a thin stainless skin collapsed revealing a large hole filled with black liquid. The forward prop also had such rusty surface spots and associated holes. The holes went deep into the prob hubs towards the inner machined surface that is in contact with the plastic bush..
I did get a replacement set off VP under warranty. After one season they too started to show the problem.
I filled the holes on the original props with "molecular metal", after cleaning out and drying the holes. They've now just done their 6th season since I did that, they don't seem to be getting any worse !
I would disagree JFM, based on my experience. I had a minor (ho ho) problem where the computer decided that I only had one engine, & 1 fuel tank where I was sure last time I looked I had two ( I had the bills to prove to Volvo in case they asked me !) An engineer came down, spent an hour checking fuses etc & reckoned that it was a faulty throttle quadrant, they ordered & replaced the £3k worth of quadrant all FOC. I am now probably going to eat my words as it will be the start of year 2 of my warranty shortly![]()
