fast_boater
Hey guys, well, picked up the 1980-83 (not sure exact year) Mercury Blue Band 500 50HP. Compression was around 120ish on all cylinders, and there was spark from every wire
I did start it it was rough because it was being stored for 3 years (3 year old gas it started on aswell), so i figure a good carb cleaning and bottom end oil changes it should be just fine.
about the bottom end, when i did pull the drain plug water ran out and then came this really white milky coloured oil but wasnt totally watery still smelt like oil and everything, i didnt think much of it because i figured it went that way from being stored because he never drove it with that oil so i figured it shouldnt have wrecked anything.
Just wondering a good way to flush the bottom end out>? I opened all the drain plugs and poured 10w30 oil through it and let it drain out the bottom until just clean oil came out, but what does the "FLUSH" drain plug do?
How hard would it be aswell to pull the lower half of the bottom end off? How hard to change the impellor? What would also be a good way to make sure all the "gears" are good after sitting with that crappy oil?
How hard is it to rip the carbs off to clean them and how would i do it?
Thanks for all the help i know its long but i hope somebody can help me. I'll probably have more questions in the future thats all i can think of right now.
