Phantom 50 fuel gauges.
Noto
15 May 2015
I recently purchased a Fairline Phantom 50 from Fairline Mallorca (south).
Following our survey and filling the fuel tanks on departure from Mallorca to mainland Spain we noticed a significant difference of fuel taken on board to the reading on the helm fuel gauges.
Contacting the broker, who actually was the previous owner , he replied that the gauges always functioned correctly. Knowing the yacht had been stood in the berth the reason could be that the sliding float may be fouled and the 250 mile trip could in fact clear the problem. Unfortunately even though we suffered some inclement conditions on the journey the gauges are still inoperable.
So my questions are :- has anyone had the experience of replacing the sender units , or is an alternative method available with the technology of today.
Im was a mechanical engineer and in my earlier years could have approached this issue myself but now my agility has waned.
I need to know exactly where the sender is situated on the top of the tanks and hopefully an access panel could make the job easy as it looks a bit cramped in the engine room.
Another question is , do the tanks have a drain valve where I could design & install a sight gauge.
The actual replacement sender is quite cheap @ £40 but access is the problem even for a lithe person.
I was told by an ex Fairline employee that all the seats on the s/bd and the TV unit on the port may have to be removed for access ?.
Has anyone tackled this job, all assistance would be greatly appreciated.
Also on our crossing the C120 /W plotter, variable control button ( located at the bottom right hand side of the screen) detached from the panel, I need a replacement. Any ideas where I might purchase.
Any information would be welcomed
KR
Noto
John100156
31 Oct 2007
SANT CARLES DE LA RAPITA
Hi Lester - I had a similar problem on my last boat a Sealine F43. Fortunately I was able to remove the port seats and found an access panel below the carpet, above the sender which allowed me to do the job.
Firstly, if you can take pictures below above the tanks in the engine room you might see if a panel exists (expect you have tried that) or at least where it’s situated, otherwise it’s a PIA taking the interior above to bits.
Anyway, hopefully others will be along shortly that may have a boat like yours and have done this job before.
I like the idea of a sight-glass on the tanks, can’t beat a visual inspection which you can valve-off but inspect from time-to-time!
Hope you get it sorted without too much aggravation!
Corona Mia
10 Oct 2021
KR
Noto
Hi Noto…..and welcome to the forum.😀
Regarding your issue with the fuel gauges…I can’t really help with your boat, except to say that fuel gauge
senders sometime stick!
Different boat…..but mine was ‘refueled’ a while ago. Tanks should have been full, but despite the fuel truck ‘ticket’
showing a lot of litres……the gauges had hardly moved!
Went out for a ‘run’ (and after the first big wave) the gauges showed ‘Full’!
Regarding your plotter.…..I‘ve also got a C120w.
The ‘cursor button’ fell off. The waterproof plastic membrane under the ‘rocker’ button becomes brittle.
After some great advice from the wonderful people on this forum😀
I contacted a very helpful gentleman in Canada who mailed me a 3D printed replacement.
Service and delivery was great…….easy to fit…….and a lot cheaper than a new plotter!
John100156
31 Oct 2007
As said above, depending on the type of sender fitted, they can stick from time-to-time (that was the issue on my F43) but I am not sure the Phantom 50 has an arm and float type sensor fitted, but in any case the boat did a ~200+nm trip late last year from Mallorca (Portals) to Mainland Spain, which was quite bumpy near the end, so that ought to have dislodged it but it didn't.
BTW: You can get the C120W rotary dial from Coastal Rides Ebay Store - see link below:
Unicontroller Rotary Dial for Raymarine C Wide MFDs: C90w / C120w / C140w | eBay
It would be good to know from a Ph50 owner (whom has replaced the sender before), if FL fitted access panels above the senders in the floor.
Noto
15 May 2015
Yes I agree. I am currently trying to join the Fairline Owners Club, but at the end of registering it asks for a secret word that is on the Facebook pages of Fairline but I can't locate the relevant page. Can the club be joined by other means ?
Noto
petem
Cotswolds / Altea
www.fairlineownersclub.com
Noto
The secret word is either "phantom" or "squadron". However, the website now gets very little traffic as everyone has moved to the Facebook Group with the same name.
Bei Facebook anmelden
Noto
15 May 2015
Good afternoon All, Regarding my fuel gauge issue ,I did purchase 2 new senders from Fairline.
These are 800mm long with a slender stem and an external float that rises & falls on the stem indicating back the helm gauges the fuel quantity in each tank.
On my previous requests for assistance Paul Meeson (ex Fairline) advised the possibility of small access hatches could be on this 2008 Phantom 50.
Removing the seat cushions on the starboard side revealed one panel and lifting the carpet on the port side revealed another. Although Fairline were a little shy with the wiring connections (very awkward to uncouple & reconnect ) the job was fairly easy. The top assembly was a threaded connection and with the panels removed they both were extracted without a hitch.
Both helm gauges now read approx quarter full , result on that issue.
Thanks to Paul and all others who responded.
Noto
Noto
15 May 2015
I am currently installing access steps to my Eng room, Laz & internal access compartment that has a freezer, water heater & AC UNITS.
At my tender age and all the worn out body joints, I need an easier method to climb down into this area.
All these steps will have a quick release facility to remove whilst accessing the said areas.
Another item I will be installing will be Extensions from my bathing platform to extend the Rib location blocks a further 700m to give easier access to disembark.
I will post pics on completion of these assemblies.
Noto
John100156
31 Oct 2007
Haha you know that’s a Noto Typo..
Sounds good the work you have done to date, she really is a lovely boat.
We just returned from a short 27nm trip today back to Sant Carles, really great sea state and weather and boat performed very well.
Guests now off to watch Crazy Kart Race, bull and Fire Runners in Town, these Fiestas are great fun….!
