Petter oil pressure gauge
doug748
1 Oct 2002
UK. South West.
My oil pressure gauge has packed up which is disconcerting to say the least. I have found a free, black, wire but cannot figure out where to put it (so to speak). Anyone know the position of the oil pressure sender on the Petter Mini Twin?
I have tested the gauge - the oil pressure is fine.
The wiring diagram gives no clues. Brian.
pete
Here
Hi Brian From memory on the starboard side of the engine near the diesel filter there is a presure switch with two wires which turns on the field wire to the alternator after the engine has started and the oil presure is up . On my engine I fitted a tee piece between this switch and the block and fitted my oil presure gauge to this tee.
Hope this helps
<hr width=100% size=1>Artificial intelligence is no match for natural stupidity<P ID="edit"><FONT SIZE=-1>Edited by pete on 06/07/2004 21:38 (server time).</FONT></P>
