ronan_boyle
New Member
Hi all,
Just purchased a Newbridge Virgo Voyager with a Petter mini 6 sea water cooled engine, think it's the ab1w. Just a few questions:
There is a salty discharge (not that kind of site) around the cylinder block and it looks like some gasket needs replacing. Any idea where I might get a maintenance manual to attempt this type of work.
Does anyone have a maintenance schedule for these engines as I've seen other posts about replacing internal anodes etc.
Finally, the engine is cooled by a Jabsco pump driven by a pulley wheel and belt. On my boat the steel pump shaft caused wear on the aluminium pulley wheel which was held in place with a grub screw on a flat face of the shaft. A temp repair was to drill through the shaft and secure the wheel with a split pin. However this has now also failed. I'm wondering if anyone has come across this problem before on this or other engines, and can you offer any solutions.
Many thanks,
Ronan
Many thanks,
Ronan
