Petter gearbox
uforea
5 Nov 2001
Leics.
Does anyone know what type of oil and how much for an old Petter gear-box. We think it is a mini six.
Thanks Ted.
uforea
5 Nov 2001
Leics.
Hi Brian, the chap at the boatyard said it was an old Petter gearbox but did not know what sort of oil it should have.
Ted.
kireonriley
12 Dec 2002
mersyside
i have had three petter engines all with hurth gearboxes and all took a.t.f (automatic transmision fluid) indeed my present engine is a pettermini twin it has a hurth box and uses A T F kieron
kireonriley
12 Dec 2002
mersyside
doug748
1 Oct 2002
UK. South West.
Ted, The handbook specifies engine oil, as did Pat Manley in his piece on the engines (PBO No368 Aug 97).
I have heard of other gearboxes with alternative fluids but can't say why, we really need an engine expert to tell us.
Suggest you look at the dipstick (hex nut on top of box) if it looks like oily oil, there you go. Brian
ex-Gladys
29 Aug 2003
Colchester, Essex
The lube in most marine gearboxes has to deal with the clutches that engage when you select F or R... Our Vetus has a Tehcnodrive attached, the Techno handbook says ATF, the Vetus manual says engine oil... I go with the manufacturer. It ,akes sense to have a lube designed for working in friction environments for me, but make sure you get a definitive answer on what the maker reckoned
<hr width=100% size=1>Larry Botheras
Anderson 26 "Amber"
