Petrol Engines for sale
2 AQ 140 Volvo penta engines 2.5 Litre ;twin solex carbureters;need some work.
Location DUBLIN
Thanks for your reply,
price is £350 each; work is required to both water cooled exhaust manifolds,
cast iron is corroded.
Solex PH3 (?) twin carbs both have new gasket seal kits fitted; also new oil
filters;timing belts, pump impellors and various anodes;one new fuel pump
fitted with new pipework.Also new plastic cooling water manifold. Electrical
points and spark plugs and rotor arm
I 've replaced the VP with diesels and transferred the alternators to the
diesel engines; so all ,minus alternators.
Dublin is left after Holyhead or Liverpool.
Regards Gerry Boylan
thanks for the offer, AQ140 is 4CYL 2.5 litre so parts not compatable
price is £350 each; twin solex carbs; complete petrol engines minus only the
alternators;problem was corrosion of exhaust manifold;
I'm selling the petrol engines because I'm converting the boat to Ford FSDti
diesels
