boatone
Had many "engine won't start" probs over the years but now I have an "engine won't stop" problem !
What engine is it?
Is that code for Volvo?
I guess it could be the solenoid itself, you can find most of them quite cheaply if you hunt around ... but I guess you know not to look for anything with marine in the title
I'd start looking at the earthing first though
I don't think that there's anything wrong with the technology....it's just that the bean counters stop the engineers doing the job properly
By which I assume you mean that things are being built down to a price/profit formula rather than reliability target?
It was beginning to look as if the stop solenoid itself had failed, normal checks showed power was reaching it.
Yesterday I decided to ask for assistance from the PBO forum and learned things about my engine that I had not realised previously.
Unlike many engines, the engine block is not connected directly to 12v -ve. When the stop position on the switch is selected 12v +ve is applied to the solenoid but, at the same time, a 12v-ve is temporarily applied to the engine block to complete the circuit.
Tests this morning have proved the solenoid is working ok and the fault lies somewhere in the earthing side of things as many suspected.
Greatly relieved that I don't need to spend around £250+ on a new solenoid !
Bosch solenoids are super reliable particularly the ATS (Activate To Stop) type, yes they are a bit expensive from Bosch, around £75 - £90 with pattern ones from Durite being less expensive, certainly not £250!
Bit surprised OP did not acquaint himself with location of stop lever when purchasing the boat. However all just a case of RTFM.
