Chris H
I went with Keith Willis from the yachting Expert for the survey, couldn’t recommend him highly enough, kept me updated on the survey day via WhatsApp and produced a defects sheet 6am the next morning.
Thanks, I’m in touch with Didier, he is brokering the boat.Keith Willis did our survey also and I found him excellent.
As you know we are in Beaulieu-sur-Mer so if you want any local tips do let me know.
For local work I use Didier Lacoche, who is based in St Jean. He is very good, can sort just about anything out, speaks excellent English if your French is average.
I can PM you his email and mobile number.
Very good to know, a few people have said the same, I’ve not met him yet but spoken a lot on the phone.In that case you won’t go wrong. He is very honest and a really nice guy.
Google tiny jpg and load photos then down load the will be back in your photos te right size.The site doesn’t give me the option to re size the file.
Or Google Pershing 53 cap Feret
Pershing 52 Used Boat for Sale 2001 | TheYachtMarket
looks a nice one leagues ahead of anything U.K. PLC has at that L node .
Are you prepared to share the snag list ?
| Remarks | |
| 1 | The fixed firefighting system in the engine room was last inspected in 2018 |
| 2 | The fire flap on the engine room ventilation on starboard cannot close because there are cables from the passerelle blocking the fire flap |
| 3 | The flares seen on board expired in 2013 |
| Item | Remarks |
| 1 | The vertical alignment of the passerelle needs verifying, the passerelle sits low in the passerelle box |
| 2 | The VHF speaker did not function when tested and the handset cable insulation is in poor condition |
| 3 | One of the gas struts on the wetbar lid is leaking oil |
| 4 | The lock for the companionway door is missing |
| 5 | The cockpit cushions and foredeck cushions are in poor condition |
| 6 | The material on the sliding roof is in poor condition |
| 7 | The speed log fitting has broken off and will need replacing |
| 8 | The surface of the antifouling is very uneven, and this will have a detrimental effect on the hull efficiency |
| 9 | There is evidence of a minor oil leak on the portside main engine raw water pump |
| 10 | There is evidence of a water leak on the face plate gasket of the starboard main engine raw water pump |
| 11 | The aircon unit in the engine room would benefit from a service, the tray needs cleaning, the surface corrosion on the compressor needs attention. The insulation on the treated water pipework needs replacing in places to prevent excess condensation |
| 12 | The WC in the forward cabin flushed but the water did not drain from the bowl |
| 13 | The top of the fuel tank in the engine room needs cleaning |
| 14 | One of the deckhead in the saloon panels is loose, the velcro pad has detached from the back of the panel |
| 15 | There is some deterioration of the sealant around the windscreens |
| 16 | The saloon TV did not switch on when tested |
| 17 | The sealant in the forward cabin shower cubicle needs replacing |
| 18 | The lense of the starboard nav light is cracked |
| 19 | There is evidence of a minor leak on the portside main engine exhaust box drain |
| 20 | The portside gearbox oil pressure sensor was giving incorrect readings, showing max oil pressure even when the engine had stopped |
| Item | Remarks |
| 1 | The teak on the platform was replaced but one step above the platform was omitted |
| 2 | The teak on the engine room hatch is worn down to the base of the caulking seam |
| 3 | There is a dent in the stainless-steel rubbing strake on the portside |
| 4 | There are cosmetic gelcoat cracks around the aft surface of the platform |
| 5 | There are cosmetic gelcoat cracks in the corners of the roof opening |
| 6 | There is some cosmetic corrosion on the helm position switch panels |
| 7 | There is some surface corrosion on the main engine mounts |
| 8 | There is a small amount of water in the bilge under the aft saloon seat unit |
| 9 | The lacquer throughout the interior is ‘milky white’ in appearance |
| 10 | The galley flooring is stained |
| 11 | The body of the anchor winch motor is surface corroded |
Chris, first of all congratulations and all the very best for a lot of happy cruising with her!Or Google Pershing 53 cap Feret
Thanks a lot, I appreciate!That looks like a waste gate for over boost that you’ve circled, I’ll have a look and take some pics
Firstly happy to see another Pershing ownerThanks chaps, great information, my daughter has padi so I’ll send her down to do the mid season cleaning and I’m told Didier is good with ASD, the first few times out we’ll definitely have a captain of some sorts with us.
I’m also told Sunseeker have a good mechanic.
