Rob_Webb
Any thoughts on this (from a friend)?
Got a problem with my perkins 4108 / hurth gearbox combination once its been running for a while (say 1 hour). If you go to change into reverse at low revs it stalls. If you let the engine cool for 30 mins then do this it seems to work fine.
Normal temp comes up to 185-190 and stays there if you are around 2000 revs. No smoke at all.
Restarts if it stalls with no majors. Just seems to stall in reverse, if you put it into forward at lowish revs its fine...... and if its reasonably cold it can handle reverse fine.
