Perkins Perama / 100 series
Yes they are. The Perkins Perama M20, M25 amd M30 are marinised versions of the Perkins 100 series. I have a 3 cylinder 103/06 which was breifly in a canal boat on keel cooling. It does not have the raw water pump on it and the place where a raw water pump would go has a plate across it. It would be a Perama M20 if marinised.
They are a very smooth running engine with little vibration which goes with being a 3 cylinder engine.
They are also the same engine block as the Volvo MD2020 and MD2030. If you know your engine number I can tell you what it is and when it was built. I am just going to paint my dagger board in a few minuites so might not be back here for a bit.
Rick,
All developments of Japanese Shibura base engine licenced by Perkins.
The name Perama was applied to the first marine versions of the Perkins 100 Series industrial engine, varouus bore/stroke configuations around same base engine design. When Perkins dumped out of marine market passed to Volvo.
Current Volvo D1's use the Perkins Shibura base which was heavily re-designed Tier II engine with bore/stroke of 77mm x 81mm. Older versions were either square or undersquare bore/stroke.
Manifolds only interchangeable on earlier engines.
Both previous posts correct. The Parama was a Japanese engine badged by Perkins and later sold to Volvo to replace the crappy old 2000 series. It's a good little engine!
