Biscay 36
Fuel oil is getting into the engine oil, not in great quantities and only intermittently, three times in the last 200 hours. I have a fuel tap on the day tank which gravity feeds the injection side and I mostly turn it off when the engine is not running; the leak off pipe goes back up to the day tank. The last time the problem occured was after a filter clean and change when I left the fuel tap open for some time before bleeding the system. The system has been in place for several hundred hours before this problem started. My search here came up with, lift pump seal, injection pump seal or a dribbling injector but would that account for the intermittent nature of the problem? Any other suggestions would be welcome?
