StefanSG
After coming up to temperature (with a little puff of steam) every three or four minutes the temperature gauge shoots up to the top of the green zone, and there is a small amount of steam for 10-20 seconds and then the temperature gauge shoots back down for another two or three minutes of normal operation. The engine doesn’t overheat generally, but the steam concerns me because it will add to the scaling and blockage in the manifold.
I’ll try and describe my current setup, things I’ve already tried, and things I think might contribute.
My engine is a recently rebuilt MD-11 C good compression cooling channels all cleared out in jackets and manifold. New gaskets all round, valve seals etc. Correct brand new thermostat tested. Pumps water fine although it sprays the water out of the transom.
I currently have a Vetus waterlock exhaust - the exhaust pipe loops down, around under the engine comes up around the flywheel, enters the waterlock on the starboard side of the engine and then exit the transom. I am worried that this set up might be contributing to an overheating problem I’m getting especially as the waterlock has risen up to the same level as the manifold. (I will try fixing it securely below the manifold as my next move) Perhaps a pressure or water build up in the exhaust ?
The whole engine is above the waterline by 18”
And if I get rid of the big loop, how can I get a vetus muffler in the system when the exhaust elbow is about 9 inches from the transom hole
Thanks in advance, at my wits end with this one, manifold currently off for another inspection and flush.
