PARTS FOR A NANI 4390TDI
burty5
21 Nov 2020
HI GUYS BOUGHT BENETEAU ANTRES 760 LOW HOURS NOTHING BUT PROBLEMS AND COST SPIRALLING TO PUT THINGS RIGHT THAT SHOULD HAVE BEEN DONE IF REALLY LOOKED AFTER
OK WHERE CAN I GET PARTS THAT ARE AFFORDABLE NOT PEACH......... E.G.
REPLACEMENT CAM BELT, NEED NUMBERS OFF ONE TO CROSS MATCH IF ANYONE HAS THEM PLEASE LET ME KNOW
HEAT EXCHANGER O RINGS
HELP!!!
Fishtigua
19 Jan 2013
Guernsey
HELP!!!
Nanni 4.390 200hp diesel
jamie langstone
22 Dec 2013
I went to a company called rough trax and they supply all the parts for the base engine 1KZ . You will see i had the 4.390TDI from the link above. Any questions just ask I know a fare amount about the engine .
burty5
21 Nov 2020
Hello thanks for replying what the problem is that we do not have the numbers on our timing belt to cross reference with motor factors who are asking for numbers and letters, there are not any on our belt and do not want to pay the £500 quoted to replace the timing belt, do you happen to know the numbers letters for the timing belt that we could use please. Thanks again
KevinV
12 Oct 2021
The landcruiser forum (as above) has some amazing folks who have saved my bacon more than once.
Head over there with your engine number, I'd be astounded if they aren't willing and able. Just don't use all caps at them, and don't say anything rude about Toyota :)
dpb
14 Feb 2007
Poole, Dorset
The Toyota Belt number is 13568(-)69085
The pulley and tesioner Toyota OE Reference 13505-67040.
or BLUEPRINT ADT37609
as a check belt should be 25mm wide with 102 teeth.
Roughtrax kit for all the above Toyota CAMKIT012
I should add that the above is from my own investigations and asking others. I have two of the above kits from Roughtrax ready for fitting next year on my boat. I wont know that the items are 100% correct till I fit them but all the other parts that I have sourced in a similar fashion have been perfect so far.
You need a cam belt cover gasket and potentially seals for the waterpipe you will be removing from across the front of the engine to allow removal of the cam belt cover . (Thank you Jamie Langstone!)
