tcm
ocean trip coming up soo.... time to think about whether to use parachute anchor or series drogue, again. "Again" because for most if not all trips these things stay in the lazarette.
The parachute anchor goes over the bows, and then acts like an anchor, bows into waves.
The drogue slows dow n the boat and means when you run downwind or downwind ish the drogue stops the boat from falling too fast down wave fronts and/or broaching.
My own exp with this parachute anchor on another boat as practice in 20knots of wind was that the boat yawed about 40degrees each way so only used it once on that boat ...as obviously no flippin good ,,,to be effective the boat *has* to hold firm on para anchor with not much yawing at all - to ride clean over (or through, a bit, if breaking) the oncoming wave. Yawing even a bit like 10degrees risks the bow getting pushed off wavetop and whole boat then all ovr the place for next wave... prhaps falling/sailing sideways down back of previous wave and/or twanging up towards anchor, hence then lying possibly sideways in the trough, ready to get smashed broadside by the next wave. Which is no blimmin good.
Being a bit motorboaty, i have tackled biggish seas in 35ish knots off spanish coast but using two diesel engines to play around as sails a bit speculative in big wind - although steady setting allows a snooze, or might do....although probly not....
So i am thinking ...perhaps have a go with engine(s) as well as para/drogue?
None of the stormy stories seem to have tried this, it's engine off and rush around the deck ....when the real issue is to hold the orientation of the boat relative to next wave, and elsewhere (like frinstance in a marina) you might well adjust exact orientation of a boat using engine.
So how about with para anchor just run motors in gear at idle to hold the boat going dead astern pulling against parachute? I think i will have a practice and try this, cos the yawing is the big prob. It sounds as tho there would be loads of load but in fact there is plenty of slip around props etc...I think.
Drogue has different problems, aim being to run downwind slightly slower than the waves. At least this means apparent waves speed is slower and less crashity, although on stern. Again, i would have no problem running engines at idle ready for trimming stern up with engines, given drogue streamed well astern...
Note that boat in question is a cat, so praps better ability to manoevre with two engines. Not sure that the manoevrability extends to reversing up wave fronts (!) but quick jabs could be useful with a drogue, or gentle rumble with parachute...
Of course, i am game to try anything. All views welcome.
