MattA24
New Member
Hello hello,
Now that the weather here in the UK is finally threatening some reprieve, I'm hoping to repaint the GRP hull of my boat. I've read pretty much everything this forum and the internet at large has to say on the topic, but I'd like to just check that I'm on the right track.
The boat is is 70's and low value. It has it's gelcoat on the topsides, but that's been 'touched up' with paint here and there by the PO.
On the topsides, I plan to abrade the surface with a sander, removing as little gel and as much touch-up paint as possible, fair out any marks with West if necessary, then paint with a couple of coats of the posher type of Dulux Weathershield.
Below the waterline is pretty smooth, so I plan to rough things up and get rid of anything loose, apply anti-foul primer to necessary patches, then antifoul just before putting in the water.
The iron keel is bubbling in places, so I plan to strip the paint, red oxide it, epoxy it, prime it, then antifoul it.
Does this seam reasonable?
The datasheet for the Trade Dulux Weathershield recommends no primer for clean good quality surfaces. Obviously that's for houses not boats. Does this forum recommended primer between gelcoat and Dulux on topsides?
Much obliged for your assistance,
Matt
Matt
