Paddlewheel tranduscer...
scadding
22 Sep 2009
If a sportsboat boat is fitted with a paddlewheel style thru-hull transducer (which I assume measures speed via its rotation) does that mean that the usual method of measuring speed via the small hole on the outdrives and the associated small pipe that connects to the lower unit become redundant?
gjgm
14 Mar 2002
London
As long as it is plugged into something, then yes !
scadding
22 Sep 2009
Am I correct in thinking that the paddlewheel transducer can only measure speed??.....i.e. it would not have been installed for any other purpose.
PhilipF
1 May 2005
Bradford-on-Avon.
No. On our Nimbus, the Transducer not only indicates speed through the water, but is gives trip distance. Also keeps a running total that the boat has travelled. The latter would be of interest providing that the wheel runs freely every time the boat is used.
Trouble being this is often not the case with our boat!
GrahamHR
12 Nov 2009
Cheshire
Isn't it the gauge that the transducer is connected to the thing that records trip distance/ total distance rather than the transducer itself?
