Paddle Board Woes
Irish Rover
5 Feb 2017
Türkiye
We have a 9' SUP which we bought in Decathlon a few years ago. It's always been stored on deck lashed to the rail. We bought a new boat in Croatia earlier this year and I took the opportunity of being in the EU to buy some stuff for the boat from SVB including a new 10'8" SUP. I didn't inflate this board until early June and now after a couple of months use it's literally falling apart. I'm talking to SVB about it and it's getting complicated. I'll post more when we reach a conclusion or an impasse. Anyway, we recommissioned the 9' board earlier this week and all seemed OK until today when we came to the boat and found it deflated - a section of seam on the side has lifted. I've glued it now and waiting to test until tomorrow.
The temperatures here since early June has been hitting 35/36⁰ every day, and occasionally higher. I'd imagine something stored on deck under direct sunlight gets much hotter. I'm assuming therefore excessive pressure has caused the failure. I don't really have somewhere shaded to store it unless I deflate/inflate every day. So, what to do? I was thinking to leave the board a bit under the recommended pressure of 15psi, say 13psi. Anyone any recommendations?
Fr J Hackett
26 Dec 2001
Saou
Perhaps UV degradation has played a part, can you get a cover for it?
ylop
10 Oct 2016
If 35C is an official “met office” temp that’s measured in the shade. It would not be at all surprising if in the middle of the day objects left in direct sun were reaching something like 50C, and if they have strong colours maybe even more. The way your soften the glue on inflatables to unbond it is with heat - and a hair dryer and enough time will get there so no surprise if your paddle boards get to that. The pressure inside will increase with temperature and will help push apart any weakened seem. Perhaps some carefully constructed covers - not too tight fitting would keep them shaded - realistically though glued inflatable seems are always going to be an issue at those temps. Does anyone make a fully welded seam version (not sure if that is possible).
Aja
6 Nov 2001
"Charles’ law, also sometimes referred to as the law of volumes, gives a detailed account of how gas expands when the temperature is increased. Conversely, when there is a decrease in temperature, it will lead to a decrease in volume."
Fr J Hackett
26 Dec 2001
Saou
V(1)/T(1) =V(2)/T(2)
Since the temperatures are in degrees absolute then the difference in volumes for relatively small changes in temperature is smaller than people with only a moderate understanding of the gas laws might suspect. 😁
Irish Rover
5 Feb 2017
Türkiye
I'm sure there's an element of UV degradation but the leak is in an overlapped seam so it looks more like the glued seam has failed due to a combination of heat and pressure. A cover will protect it from UV but I guess it won't do much to reduce the heat or pressure and I'd rather not be messing with putting it on and off. A solid board would obviously solve the problem of leaking but they're heavier to be hauling around the boat and multiples of the price of an inflatable - it'd be cheaper to replace the inflatable when it fails.
I'm a proud Paddy and I'll be having none of yer King's laws, thank you all the same.
I'll inflate it tomorrow and see if the repair holds and leave it a couple of psi short of the recommended 15.
Fr J Hackett
26 Dec 2001
Saou
Sadly as the combined gas law indicates a small drop in pressure is unlikely to solve your problem.
(P(1) V(1))/T(1) =(P(2) V(2))/T(2)
Ye canna beat the laws of physics.
Ribtecer
23 Aug 2006
I recently had my board with me on the Gulf Coast of Florida in very hot temperatures, my board also has a recommended operating pressure of 15psi. I have a little SUP pressure gauge and I kept mine at 10 psi in that heat. Still very usable at that pressure.
A cover does sound like your best bet.
Fr J Hackett
26 Dec 2001
Saou
Don't forget that once it's in the water it will quickly adopt the ambient water temperature, you don't want a floppy board or for that matter a floppy anything, it could have embarrassing consequences.
Bodach na mara
21 Aug 2002
Western Scotland
To add to the contribution by ylops, the temperature in Scotland has been nowhere near 35 °C recently yet one day last week I could barely touch the deck, let alone sit on it. It's surface temperature must have been well over 60°C.
Maybe your solution lies in storing the SUP out of the sun, probably deflated.
KompetentKrew
27 May 2018
SVB are abysmal when you have a problem. I wish you better luck than I had - I actively try to avoid them now, and it's a pain in the ass. I spent thousands with them and my letter to the CEO was ignored, all over a very small matter.
