john_morris_uk
Has anyone got any thoughts as to the preferred spacing between the shaft anode and the p-bracket and the p-bracket and the propeller on the prop shaft? On the one hand it would appear to be better if there was a fairly small gap between the p-bracket and the shaft anode (just f'wd) and the prop (just aft), but I seem to remember that the rubber cutlas bearing needs a free flow of water. Is there an advised gap to allow water flow, or will sufficient water get in anyway? What do people think? I am in the process of fitting a new prop and shaft so I can choose where to put them all! The boat is a fin keel cruiser-racer. One inch shaft, 25 HP motor.
