p-bracket to anode & prop spacing?
john_morris_uk
3 Jul 2002
At sea somewhere.
Has anyone got any thoughts as to the preferred spacing between the shaft anode and the p-bracket and the p-bracket and the propeller on the prop shaft? On the one hand it would appear to be better if there was a fairly small gap between the p-bracket and the shaft anode (just f'wd) and the prop (just aft), but I seem to remember that the rubber cutlas bearing needs a free flow of water. Is there an advised gap to allow water flow, or will sufficient water get in anyway? What do people think? I am in the process of fitting a new prop and shaft so I can choose where to put them all! The boat is a fin keel cruiser-racer. One inch shaft, 25 HP motor.
<hr width=100% size=1>
I would fit it about 2" from the rear of the 'P' bracket - as long as it can 'see' the prop you will be OK. Have also seen them about halfway between the P bracket and the deadwood?.
I would allow about 1½" between the P bracket and the back of the prop - you will then have enough rooom(I think) to fit a Rope Cutter - See
<A target="_blank" HREF=http://www.ropestripper.com>http://www.ropestripper.com</A> - Ambassador marine who should have the info on their website.
It is always possible to shorten a shaft, very difficult to lengthen it!
<hr width=100% size=1>dickh
I'd rather be sailing... :-) /forums/images/icons/smile.gif
About half-way between the p' bracket and the hull is ok, but to be honest i wouldn't bother - they don't work very well anyway unless your boat is sat in a marina most of the season connected to shore power.
Not just ranting - i can back it up!!
There is another consideration. Putting a heavy weight in the centre of the shaft span can have quite an effect on its rotordynamics. You could cause quite significant vibrations by doing this. I seem to recall that a gap of 10 mm is sufficient for entry of water to the cutless bearing.
Thanks for the comments chaps. Regarding whether the anode works or not. Well we are not stuck in the marina all season - Last year we were in Ireland, then the solent, Channel Isles and Brittany, and it was obviously working as it was half eroded away when we hauled out. I was tempted to put it close to the p-bracket as some of the anodes come shaped as if they are supposed to be near something - others are more rounded as if they are designed for more mid shaft.
Happy sailing!
John
If you put your anode foreward of the p bracket, leave a large enough gap to be able to slode the prop shaft aft in order to disconnect the gearbox / shaft coupling in case you need to check / realign the engine. Don't get caught like I did, unable to undo the coupling because the shaft would not slide back far enough.
Cheers
John.
