Murv
OK, so my old boat is finally sorted out, it's developing full power and really flies. But, now it overheats.
Usual story, I've no idea what sort of temperature it used to run at as it's the first time it's ever been running properly.
I've done the usual things, strainer is clear, new pressure cap on the heat exchanger, new thermostat on the closed system, fresh 50:50 antifreeze in the closed system, both pumps appear to be working.
At displacement speed, no problem, temperature is stable and sits at around 90degC for hours at a time.
As soon as it gets on plane, it rapidly gets to over 100degC and blows clouds of steam out of the exhaust.
On a flat out run last week it jumped to 120degC before it blew all of it's coolant out.
Now, I'm not sure if the problem is the increased revs and fuel burning that causes the overheat, or whether the raw water system cannot draw enough flow when on plane. It's obviously a difficult thing to test!
What I'm thinking of trying is running the boat against the tide (we have a fast tide run here) so that revs are fairly high, but boat is displacing to see if it gets hot. Trouble is I can't run it at too high revs otherwise she'll plane.
The other slight problem is I'm on a speed restricted tidal river so need to limit testing to 6 knots. I can do brief faster runs just upriver in the water skiing area otherwise it's a journey downstream to where the speed restriction lifts, but then obviously a real pain getting back if I suffer engine failure through overheating.
Boat: 22' cabin cruiser, planing hull
Engine: Ford FSDTI (marinised Transit engine) 2.5 Turbo diesel.
Cooling: Jabsco raw water pump through Bowman heat exchanger, water cooled exhaust, turbo and oil
Outdrive: Volvo 270 (as far as I can tell, the cooling system has been removed on this as it's redundant)
Speed: Top speed around 26 knots, realistic cruising probably around 16 knots.
One thing I'm suspicious of is the raw water intake. It's just a conventional, flat, through-hull fitting. From the Googling I've done, some suggestions are that the water intake must be a scoop type, otherwise the raw water pump cannot draw enough through, but other sources seem to suggest that this is unnecessary. However, it's been configured like this for the last 10 Years so presumably it must have worked in the beginning.
Any ideas where I should start? It's a little frustrating finally unleashing all this power after nearly 18 Months of owning the thing, then not being able to use it!
Cheers,
Chris
Cheers,
Chris
