Keithleask
Hi all again, I posted a couple of weeks ago about my overheating stbd engine, well after removing all the hoses except from the leg to the raw water strainer and checking for bits of impeller etc , removing and cleaning the heat exchanger, I did not remove the exhaust elbow as these were new about six months ago, replaced raw water pump for a re built one, I put it all back together today and ran the engines up. I tied up securely and put some drive on to load up the engine up a bit. The gauge eventually ( after an hour or so) went up to 150o , the port engine stayed solid at 125o. Felt the raw pump ( it was getting hot previously) and it did get warm for a short time then went cold like the port engine and stayed like that. I did hear that on these KAD 42 s that the stbd engine runs hotter than the port engine because of the caorifier, is that correct ? I also noticed that the drive dog behind the raw water pump was quite badly split and was wondering if this might have been slipping and adding to the problem. I have ordered new ones,
The manual says these engine should be between 165/195o , I am still not convinced that I have sorted the overheating though cleaning out the exchanger was probably overdue anyway, anyone have any more views on the above ??? Thanks ,
