kilkerr1
Hi again
Outboard engines and shaft size: when described as having a 'standard' shaft, is this the same as when it's described as having a 'short' shaft? I need a short shaft outboard apparently for my Kingfisher 20+ (which has a cunning outboard well you tilt the outboard into and then closes, so it's like an outboard/inboard engine), and am wondering whether a standard shaft will do the job/fit, if it's ultimately the same length as a short shaft.
Thanks!
Thanks!
