Outboard not starting.
munster1967
20 May 2024
Hi folks.
2 HP 2 stroke Suzuki started today ran for 15 seconds then wouldn't start again. Was running perfectly before this. ??
johnalison
14 Feb 2007
Essex
NB I am not an engineer, but when my 2.2 Suzuki did the same thing it was cured by using fresh instead of old petrol. I have no doubt there are at least forty other possible reasons.
Aja
6 Nov 2001
Hi folks.
Persevere with new petrol - highest octane you can reasonably get.
I wouldn't give up my 2hp Suzuki for anything. Always, but always starts first pull.
Edit : don't over do the 2T - 50:1 is plenty. 100:1 is better.
wonkywinch
30 Jul 2018
Hamble, UK
Had plenty of two stroke garden tools. They were a bu$$er with old (ethanol %) petrol that gummed up the small carbs. In the end I used very expensive premixed fuel (Motomix) but I guess this wouldn't be economical for an outboard as it's £5 a litre.
Is non ethanol petrol available anywhere these days?
munster1967
20 May 2024
Very expensive fuel. 🤔
B27
26 Jul 2023
New petrol
Clean carb
New spark plug.
There are plenty of other things that can go wrong, too much oil building up in the crankcase, choke not coming off, electronic ignition, kill switch....
Very often a motor which 'just won't start' will respond to angry bloke pulling the string harder at full throttle....
Mark-1
22 Sep 2008
Fresh Fuel, new spark plug. Bet it starts.
If it still doesn't run, check for spark and if there's spark clean the carb.
Whatever this is it will be trivial.
Minerva
16 Oct 2019
I'd do this and clean the carb at the same time.
You can buy carb cleaning tool from amazon - looks like a multitool with various sized wire pipe cleaners /. wires. Costs a quid or so and makes the carb cleaning process trivial. Worthy of a place in your onboard toolbox.
dunedin
3 Feb 2004
So is this premium at the petrol pumps. ??
Name depends on the brand, but basically yes - a slightly more expensive petrol. The petrol station nearest Largs marina for example has a pump labelled E5. Not all places sell it so I search out at start of season.
If your fuel tank hasn’t been drained in the 3 years, nor the carb cleaned (a 10 min job) this is likely the reason, as above.
srm
16 May 2004
Azores, Terceira.
Quietly rowing ashore in Rhum anchorage passed boat with two angry blokes in dinghy. Had a pleasant walk ashore. Rowing back to the boat a couple of hours later passed same two now very angry blokes still pulling a bit of string. The amount of energy being expended would have easily taken them ashore and back four or five times if they had a decent pair of oars.
Sandro
20 May 2004
Northern Italy
@ srm
This reminds me of the advise in the Seagull Owner Manual of 60 years ago: "If it does not start at the second or third pull there must be a reason; do search for this. Keeping on pulling the starter only worsens things".
