TSB240
I do have a blanking plug, but lifting the outboard and putting it in a locker is just not
practical for me. Apart from the weight and awkwardness I have a long trip to find the open sea. I sail when I can but narrowness , commercial traffic , and other yachties make the
engine always available. The 4 stroke is also considerably quieter and has a much longer
range than the 2 stroke. I did try a 2 stoke once but it set off my smoke alarm located in
the cabin despite being unable to see fumes.
Each to their own of course.
I used to run a Tohatsu 9.8 Hp 2 stroke in a well with our trailable yacht . I never found the fuel consumption a limiting factor and we would typically use just under a gallon an hour. The only 4 stroke alternative available that fitted the well was a single cylinder 6hp Tohatsu. This actually used the same leg as the 9.8 2T. The appeal was it should have halved my fuel consumption in reality it made little difference.
It was useless in short chop which stopped the boat though marginally better with a saildrive prop. Any gain in efficiency was lost in having to use far more throttle for the same performance.
The noise was slightly muted but the transmitted vibration of the single cylinder through the hull was much more pronounced than the sewing machine frequency of the twin cylinder two stroke.
I very much doubt your additional considerable range as there is only about a 10%-12% difference in fuel consumption between equivalent small hp models.
Fumes in the cabin were eliminated by using the Tohatsu approved leg vent which was piped through the transom.
The weight and size of the 9.8 2T was such that I became quite adept at switching it between locker and well at short notice especially in confined areas on our way out to sea.
I was much happier with the well fairing plug in and gaining an extra knot of boat speed under sail and total peace without the sound of engine or prop spinning and well gurgling. We also kept a much drier cockpit!
