Greenheart
Six months after taking delivery, I finally started my 15-year-old 5hp Mariner 2-stroke. It was no great effort, started on about the sixth pull, even though I had no idea what I was doing with the choke. I was dazzled that I managed not to over-fill the water-tank - it didn't slop over the side even when I put it in gear! :biggrin-new:
Apart from being appalled (though not surprised) at the way it turned 60 litres of crystal-clear drinkable water into opaque brownish scum in five or six minutes, I'm very happy, but I do have questions that I hope readers can answer.
A small point first: the cooling water tell-tale...even before the engine started, a jet of water squirted out of the tell-tale when I pulled it over. Once the engine was running, the water poured out and I was confident all was well...
...but after perhaps five minutes' continuous running, the jet of water had reduced to a dribble or steady drip, even if I revved the engine. I think I've heard that this isn't a serious cause for concern, but I'd like to hear it again here.
More seriously, there seems to be an issue with the way the engine is meant to be locked in the 'down' position. A neat little spring-loaded metal flap accessible from either side, lifts, apparently to unlock a hooked frame which looks like it should lock onto a bar fitted between the holes visible on both sides...
...except, there's no bar between the holes, so there's nothing for the hook to hold onto. I can see that there are also hanging bars with ends that stick out sideways, which look as if they could lock into the holes...but at no angle I tried, did these bars line up with the holes...
...so as the engine was running, it wasn't especially secure in its orientation - and if I'd run it in reverse, I'm certain the prop would have thrust itself to the surface.
There may be something wrong with the set up, or with how I've positioned the 'dogs' or screws on the timber frame, although that looked very straightforward, and no different to how it would fit on a transom or bracket.
The spring-loaded pivoting frame that doesn't hook onto anything, looks like it should engage with the shiny steel pin sticking upward in the pic below...but again, it doesn't actually make contact.
Maybe someone has seen all this before and knows what's wrong, or what I'm doing wrong? Thanks in advance.
